What You Should Know About 360 Lace Frontal
alihair
Postby alihair » Mon Jul 01, 2019 1:13 am
360 lace frontal are getting more and more popular among women in the whole world, many people are confused about hair bundles with Lace Wigs. Here are some tips to help you have a clear cognition to 360 lace frontal.
Let'S Talk About: What Is A 360 Lace Frontal Exactly?
Essentially, 360 lace frontal closure is also called 360 frontal for short, it is 360 degrees lace surrounded so that it allows you to give your hairline a break when you are wearing it. It is essentially a Lace Front Wigs headband that has adjustable hooks in the back so that it can get nice and snug without needs to use glue or tape or even sewing it on as many of us do.
Whereas regular lace front closure is installed on only the front of the head, a 360 lace frontal goes all the around the head, leaving a round opening in the center, which makes it even more easy to install your wefts as well as achieve a Full Lace Wigs natural hairline around the entire circumference of your styled lace frontal in less time.
How Many Bundles Do You Need With A 360 Frontal?
Usually, only 2-3 bundles are needed to complete a perfect natural-looking when you use a pre-plucked 360 frontal closure. To some extent, it will save more time because installing a wig with a 360 lace frontal requires fewer bundles.
The Pros And Cons Of Using A 360 Frontal With Baby Hair
Why choose a 360 Lace Frontal Closure? Here are some advantages of 360 Lace Frontal Closure. First, it requires fewer bundles and save time for installing. Second, it has a pre-plucked hairline for a more realistic look when wearing. Third, it will give you a full and thick appearance if you choose hair bundles with 360 closure. Finally, it is a best choice for you to choose 360 lace if you like ponytails and updo styles.
However, there are some things that you should take care. You should maintain the adhesive regularly as it lasts for only 4-5 days hence. Also, Glue needs retouch after two weeks and may cause skin irritation. Therefore, it needs you to get the proper maintenance, proper install.
If you want to try a 360 frontal closure, you can and will be with great results. I definitely suggest 360 frontals, it’s very easy to wear, adjustable and comfortable. And our 360 frontals also have baby hair, pre-plucked and natural hairline, which is really natural and beautiful.
WestKiss Website:https://www.westkiss.com/
Evawigs
Re: What You Should Know About 360 Lace Frontal
Postby Evawigs » Thu Jul 11, 2019 7:56 am
Many customers are asking how to care their wigs, here we summered up 10 tips that may help you better care and store your wig.
1. Detangle before washing with wide teethed comb from hair ends to root. Never comb roughly from the hair root, that will cause shedding.
2. Wash your wig 1 to 3 times a week if you wear it everyday, or every few wearings as needed. As dirty hair is not manageable, and will be tangled which will cause shedding.
3. Never use hot water or cold water when washing. Hot water may loosen the wig construction, and cold water is not good for removing the dirt.
4. Always rinse human hair with the water flowing in the same direction of the hair to avoid matting and tangles.
5. When washing, pay special attention to the area around the face which may accumulate dirt, oil, and makeup.
6. Never twist or rub your wig vigorously while washing or drying.
7. Always use sulfate-free care products formulated for chemically processed hair to wash and style your human hair wigs to keep the hair soft and manageable.
8. To avoid stretching the cap, never place a wet wig on a mannequin or Styrofoam head. A folding wig stands or tall can of hairspray make the best drying platforms.
9. Have two wigs ready to wear at all times. This way when you are washing one wig, you have a back up which is ready to go. Plus, rotating between wigs also helps to extend the life.
10. If you would like to store your wig, make sure that your wig is washed and totally dry, and put into the black net when we shipped with your wig. Do not apply any product when your wig is not in use.
check evawigs.com:www.evawigs.com
high quality human hair wig
http:// www.evawigs.com
Return to “PicAXE”
Users browsing this forum: No registered users and 2 guests
