How Do You Wash A Human Hair Wig
alihair
Postby alihair » Mon May 13, 2019 7:23 am
Human Hair Wigs are expensive, but they are definitely worth it. Because they are made from real hair, they are much more resilient than wigs made from synthetic fibers when it comes to straightening, curling, and dyeing. Just like synthetic wigs, Brazilian Hair need to be washed regularly. Because of how delicate they are, however, you need to be extra careful with them.
1、Brush or comb the wig starting from the ends. Gently comb out the ends of the Brazilian Hair Bundles. Once they are free of knots, work your way up towards the roots until you can run your brush or comb through it without snagging. Use a wire wig brush for straight or wavy wigs, and a wide-toothed comb or your fingers for curly wigs.
2、Fill your sink with cold water, then stir in 1 to 2 squeezes of shampoo. Use a high-quality shampoo that is suitable for the hair type you are washing. For example, if you are washing a curly wig, use a shampoo made for curly hair. If you know that the wig has been dyed, try a color-safe shampoo instead.
3、Turn the wig inside out and place it into the water. Use your fingers to turn the wig cap inside out and leave the wig fibers hanging loose. Place the wig into the water and press down on the fibers to submerge them. Give the wig a gentle swirl to help distribute the shampoo throughout the strands.
4、Soak the wig for 5 minutes. Make sure that the wig is completely submerged in the water. Do not move the wig around during this time. Too much thrashing, squeezing, and swirling will cause the fibers to get tangled.
5、Rinse the wig with cold water until the shampoo is all gone. You can rinse the wig in a bucket filled with fresh, cold water, or you can do it in the sink or shower. Depending on how thick the wig is, you may have to rinse it twice.
6、Apply conditioner to the wig. Simply drizzle some conditioner onto the hair, then gently finger-comb it. If your wig is a lace front wig or a ventilated wig, take care to avoid the wig cap. The strands are knotted onto the lace. If you apply conditioner to them, the knots will come undone and the strands will fall out.This should not be a problem with a regular, wefted wig because the fibers are sewn on instead.
7、Wait 2 minutes before rinsing the conditioner out with cold water. Leaving the conditioner on the wig for a few minutes will allow the nourishing oils to penetrate the hair and hydrate it—just like the hair that grows out of your head. Once the 2 minutes are up, rinse the wig with cold water again until the water runs clear.
WigginsHair Website:https://www.wigginshair.com
Users browsing this forum: No registered users and 1 guest
