HOW TO BET?
User avatar
biha
HOW TO BET?
Postby biha » Tue Jun 18, 2019 10:52 am
HOW TO BET?
It is expected that by 2021 the total volume of sports betting in the world will exceed 1 trillion dollars. This is more than the budgets of India and Mexico combined. The betting industry now affects all major sports tournaments, some bookmakers even take bets on local Championships of individual cities.
Offices are not patrons that make it easy to win money. Only tiny percent of the players get from betting revenue, a small part of betterof plays with varying degrees of success, the rest are constantly losing. Without knowledge and experience a beginner will only suffer defeat. To the game, the bookmakers are not hit hard by the budget, you need to stick to a particular approach to betting.
Let's analyze all the steps of a beginner bettor, which must be passed.
1. Bookmaker's office selection Pin-Up
Bookmakers can be of two types: online offices and ground betting shops (PPS). Previously, PPP had such an advantage over online offices as anonymity. After the legalization of betting shops it was gone.
You can paint the advantages and disadvantages of each type of bookmakers for a long time, but suffice it to say that professional players preferred online betting. Their main advantages are time saving, reliability, availability of statistics and wide bonus offers.
When choosing an online office, use the following criteria:
reputation;
the size of the coefficients;
number of tournaments and events in the line;
Deposit and withdrawal methods;
player feedback;
availability of infographics and video broadcasts of sports events;
minimum and maximum bet amount;
the speed of withdrawal;
bonus offer.
First of all, the reputation of the office is important. If the bookmaker offers the most luxurious odds, but has a bad reputation among bettors, it is necessary to bypass it. The size of the coefficients directly affects your income, so before registering, compare the quotes of the office with the coefficients of other bookmakers. Infographics and video broadcasts will be useful when betting live. They can be found on third-party resources, but it is more convenient when such useful tools for betting are available in the functionality of the office.
2. Registration
Registration form in BC Vinline
Fill in the registration form without errors. Believe me, if you enter the wrong data, then sooner or later you will have problems with the withdrawal. In addition, the legal bookmakers are required to pass a mandatory verification. The office should check the identity and age of the player. The procedure is carried out in the following ways: providing a photo of a passport, Bank statement or receipt for payment of housing and communal services. Separate office carried out the verification using the departure of the letter with the code to the address of the player.
See what data you need to specify when registering at the bookmaker Winline. Specify only a valid E-mail and phone number, as password recovery takes place through the phone and e - mail address.
3. Deal with the designation of rates
Now the offices give hundreds of different betting options for individual events. You can bet on the goal of a certain player, the number of yellow cards or corner kicks in the match.
Beginners are strongly advised not to bet deep painting. First, master the markets of the main outcomes (team win or draw) and totals (number of goals in the game). As you understand the line, switch to the markets of handicaps and individual indicators of players.
Let's analyze the betting options in the match Tottenham – Newcastle on the Winline:
Winline odds for Tottenham - Newcastle 02.02.2019
«SPEs. time" – bet on the result of the match. Market P1 means a bet on the home team (Tottenham), "X" – a draw, P2 – the victory of the guest team (Newcastle).
"10 minutes" – the outcome of the match after 10 minutes.
"1 time" – the outcome of the first half.
"2 time" – the outcome of the second half.
"Totals" – bet on the number of goals in the match. For example, if you bet on "b 2.5" (total more than 2.5), then you need to win the game was scored more than 2.5 goals (3, 4, 5 or more). When betting on "m 2.5" (total less than 2.5) to win you need to have scored less than 2.5 goals (0, 1 or 2).
4. Determine what you need bets for
If you are just wondering how bookmakers work, and from the rates you expect only additional excitement when watching sports, then you can not read the article further. If you have a goal of earning at rates, then be prepared for a long learning process, which can last for months or even years.
5. Work out
Don't make big bets right away. For example, in the bookmaker winline minimum Deposit is 500 rubles, and the minimum bet is 10 rubles. Start small, master the types of bets, try your luck in live bets. In this case, do not increase the rate, always put on 10 rubles.
6. Select your sport
There is not a single successful bettor who is equally good at betting on all sports. Some handicaper spetsializiruyutsya for football, others like basketball, others, and does betting on e-sports. Moreover, professionals play in the markets of several sports leagues. You can not be competent in a large number of sports and leagues. The narrower the specialization of the bettor, the better he will be aware of his field of activity.
Choose the sport and those sports tournaments that you like the most. For example, if you like basketball, it will be enough NBA, Euroleague and VTB United League. In major leagues, bookmakers always give a wider list and higher odds.
7. Choose a betting strategy
You can't beat a bookie without a strategy. Let's say more: even the presence of the strategy does not guarantee the player success. Hundreds of betting strategies can be found in the public domain, but only a few of them are worthwhile. Ideally, you need to develop your own strategy, but this requires knowledge. Before using the strategy, you need to test it on the minimum bet sizes.
8. Learn to lose
A bad streak in the bets can occur at any time in any bettor. It is important to remain calm, not to raise the amount of bets and not try to recoup. Only the distance is significant in bets, a series of defeats in 5-7 games is not indicative. Psychological stability in betting is as important as in any other activity.
9. Don't play at low odds
Beginners are highly exposed to bets on favorites with low odds. The market with a coefficient of 1.10 at first glance seems to be a win-win, but the yield from such a rate will be very low. In order to be in the black, you need to win 10 bets out of 11. If you bet on the ratio of 1.60, then you need to win two bets out of three to succeed.
10. Do not focus on the quantity, but on the quality of bets
A novice player will undoubtedly want to cover as many sports events as possible. There are a lot of interesting betting offers in the betting line, but a haphazard game will only lead to a loss. It is best to start with one bet per day. Let you spend 3-4 hours to analyze the match, but a large number of factors that can affect the result will be taken into account.
It is not enough to evaluate only the statistics of the teams and their places in the standings. Also important are the form of the team, the microclimate in the team, the presence or absence of injured and disqualified players, the role of the coach, the demands of the judge, the weather during the match, etc. Be careful to the details, any little thing can be crucial to the result of the game.
Conclusion
The above tips – this is only the basis from which to start a beginner. As you gain experience and deepen in the details of betting results of the player will improve, but it is important not to stop in development. Even professionals are constantly studying new trends in betting in order to modify their strategies in the right direction in a timely manner. You have a long way to go, which, of course, will be a lot of mistakes, but at the end of it you will reach the main goal – to generate income from bets.
User avatar
detelina
Re: HOW TO BET?
Postby detelina » Tue Jun 18, 2019 7:26 pm
Sport bets are too sharply relevant to many users. There is no betting experience. But I'm not sure that a mathematical calculation can guarantee victory. After all, sports are unexpected events.
User avatar
kareba
Re: HOW TO BET?
Postby kareba » Wed Jun 19, 2019 6:59 am
The only rule that is worth sticking to each of us, making a bet on sports, is that you can only bet that amount with which you do not mind leaving. In simple words: without fear of losing less, you can get more. You should always hope to win, but not be afraid to lose.
KeiraBradshaw
Re: HOW TO BET?
Postby KeiraBradshaw » Wed Jun 19, 2019 8:17 am
Thanks for an informative post about betting! Today it's a quite popular theme and I think I want to start to bet on my own. Before I have only the experience with gambling like https://ipayzz.com/american-express/ and now I explore more variants in betting. It could be a really interesting topic.
User avatar
Nila546
Re: HOW TO BET?
Postby Nila546 » Tue Jun 25, 2019 10:23 pm
biha wrote:1. Bookmaker's office selection Pin-Up
Anyone who makes bets in bookmakers loses sooner or later and has to put up with defeat. It is especially hard to survive a defeat if you bet on a "vernyak" or bet an extremely large amount. The important point is that if at some time you notice that the losses have prevailed over the winnings, and you drop much more than you can afford, you need to stop betting.
User avatar
Ernest
Contact:
Re: HOW TO BET?
Postby Ernest » Wed Jun 26, 2019 12:48 am
1. Bookmaker's office selection [url]<a href="https://www.pin-up.bet/ru-ru/">Pin-up</a>[/url]
Many thanks for the topic of how to make sports bets in online casinos. I read a lot of useful information, I want to register, make a deposit and try to make several football bets according to your strategy, this is my favorite sport. When I reach a higher level as a player in a bookmaker, I will think about other sports, but temporarily I will focus on football teams.
User avatar
Ernest
Contact:
Re: HOW TO BET?
Postby Ernest » Wed Jun 26, 2019 1:00 am
biha wrote:HOW TO BET?
DeboraDyn
Re: HOW TO BET?
Postby DeboraDyn » Fri Jun 28, 2019 10:42 am
Hi guys! Tell me how do you do it? I tried to bet (football), but the result didn't inspire me. I either lost the bet or won the minimum. Now I'm tired of these attempts. I decided to try usa online slots. I understand that certain knowledge and experience are also needed here, but at least there is a free deposit so that I can learn the tricks.
User avatar
detelina
Re: HOW TO BET?
Postby detelina » Thu Jul 25, 2019 7:20 am
Many people are interested in rates and money.
allok
Re: HOW TO BET?
Postby allok » Fri Jul 26, 2019 6:12 am
Thank you for the interesting post. The topic of sports betting is also relevant for me. To bet, I use analytics and bookmaker forecast https://1xbetting.org/. I do bets in real time
Return to “Arduino”
Users browsing this forum: hieu16005, kosal66, Taiphan000 and 2 guests
